Hi all.Yet another laptop that cuts off as the power button is pressed.
When you press the power button, its led is lit and after 2-3 seconds the laptop cuts out. Same issue with and without battery. Also same issue when the MM is out of the laptop's housing. I have also reballed the GPU but same issue.
Testing few coils I think one is short. I get shorts at both points when testing. See image:
Вложение:
Can anyone tell me the name of the replacement coils or a schematic to look at? Thanks.
