Текущее время: 16 апр 2024, 21:51
 Заголовок сообщения: x53U (LA-7322P) Power Cuts Out
СообщениеДобавлено: 16 июл 2013, 20:22
Hi all.Yet another laptop that cuts off as the power button is pressed.
When you press the power button, its led is lit and after 2-3 seconds the laptop cuts out. Same issue with and without battery. Also same issue when the MM is out of the laptop's housing. I have also reballed the GPU but same issue.
Testing few coils I think one is short. I get shorts at both points when testing. See image:
Can anyone tell me the name of the replacement coils or a schematic to look at? Thanks.
 Заголовок сообщения: Re: x53U (LA-7322P) Power Cuts Out
СообщениеДобавлено: 16 июл 2013, 22:09
You do not need to replace coil. Measure resistence on all coils and write down here. Also see mail
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 16 июл 2013, 22:33
Thank you! Yes I see the email. I'll let you know tomorrow when I am at work. ;)
СообщениеДобавлено: 17 июл 2013, 13:36
Ok, when using a multimeter and testing the coil itself:
PL202: 0.2 ohms
PL204: 0.2 ohms
PL401: 0.2 ohms
PL305: 0.2 ohms
PL303: 0.2 ohms
PL701: 0.2 ohms
When testing from ground to coil:
PL202: 15.2 ohms (sometimes to 18ohms)
PL204: 179.2 ohms
PL401: 1.55 kilo ohms
PL303: 65 ohms
PL305: not stable. Starts from 1 mega ohms down to kilo ohms then to ohms then back up to kilo ohms
PL701: 0.5 kilo ohms
СообщениеДобавлено: 17 июл 2013, 14:14
you need check which voltages are power up (RAM - 1.5V and 0.75V, 5V/3.3V, APU, CPU core FCH core and so on).
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 17 июл 2013, 14:42
Thanks but not sure where to start with your guide. Can you simplify it for me a bit?
СообщениеДобавлено: 20 июл 2013, 03:27
Measure all the voltages on all the coils after switching on.
Are you understand that if any of these voltages is not presented, laptop would safety shutdown.
兰克乌是松尔赫, 你操舰军斯罗俄
В этой теме нет новых непрочитанных сообщений. Lenovo Y560 (DAKL3AMB8E0) Power cuts off after lenovo logo
abuholm
28 апр 2014, 23:13
abuholm Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus X53u (LA-7322P) нет изображения
acerr
22 июн 2014, 17:47
unit1 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. X53U (LA-7322P) прописать серийник
ucpaul
16 дек 2014, 20:38
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. X53U (LA-7322P Rev:1A) Не видит SATA
john_dh
4080
23 янв 2015, 13:16
john_dh Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS X53U (PBL60 LA-7322P) через 3 сек. выключается
bek17
13 июн 2015, 14:46
bek17 Перейти к последнему сообщению
Сейчас этот форум просматривают: Kacher и гости: 14
