Текущее время: 20 апр 2024, 11:48
alifakhrniya
Заголовок сообщения: A42j (K42JP) no boot Добавлено: 30 июл 2013, 01:24 |
Сообщения: 138 Откуда: iran,azerbaycan
I have asus a42j(MB ver:k42jp),I received this laptop 1 month ago while sometimes did not boot up and fan works in high speed ,I resolded gpu chipset(ATI 216-0772003) but trouble did not solve,so I reballed gpu and solved trouble and laptop worked about 10 days normally without any problem,after 10 days the toruble appeared again and reballing did not solve problem so I changed gpu chipset with new one,trouble solved and laptop worked about 1 month and now again I have the same trouble,I resold gpu and now system did not boot up at all,I hope gpu chipset is intact..i need Thoughts ….. Bios is true. Voltages on gpu (ATI 216-0772003)- 1.08v ,1.5v , 1.8v.
unit1
Заголовок сообщения: Re: A42j (K42JP) no boot Добавлено: 30 июл 2013, 12:56 |
Сообщения: 1944 Откуда: Ukraine
alifakhrniya писал(а): I am sure the bios is true. if you sure next check RsM писал(а): Next- PCH, next - GPU.
unit1
Заголовок сообщения: Re: A42j (K42JP) no boot Добавлено: 01 авг 2013, 16:34 |
when you m\b is working you can see active wave like the adress bus on the memory kbc you must see it at the adress bus lpc (lad0-lad3) and lpc frame you must see wave 33rHz if you see active at the lpc I recommend to you soldering the postcard . sorry for my bad English/
unit1
Заголовок сообщения: Re: A42j (K42JP) no boot Добавлено: 04 авг 2013, 13:19 |
alifakhrniya писал(а): I think system could not start because RST is active all the time,is that true? no,reset must be 3v after it it will be 1,5-2,5v miliseconds and after it 3v/ look this screen
unit1
Заголовок сообщения: Re: A42j (K42JP) no boot Добавлено: 01 сен 2013, 18:10 |
alifakhrniya писал(а): Is this time sequence global on any systems? for asus - yes!
