ASUS K43JA (K43JA) NOT BOOT BY CORE I7 CPU https://vlab.su/viewtopic.php?f=40&t=18106 |
P.zonouz [ 04 янв 2014, 19:23 ] | |
Заголовок сообщения: | ASUS K43JA (K43JA) NOT BOOT BY CORE I7 CPU |
There is a strange problem, Laptop not boot by Core i7 but boot and working ok by Core i3!!!. Bios sewed. Any idea?? |
RsM [ 04 янв 2014, 19:28 ] | |
Заголовок сообщения: | Re: ASUS K43JA (K43JA) NOT BOOT BY CORE I7 CPU |
A software limit of BIOS Also for I7 need 3 phase of CPU core power |
P.zonouz [ 04 янв 2014, 19:52 ] | |
RsM писал(а): A software limit of BIOS Also for I7 need 3 phase of CPU core power So what can I do? You have any compatible BIOS? or suggest to dig CPU feed? |
RsM [ 04 янв 2014, 21:53 ] | |
I think you shouldn't install I7. Also it is very hot (think about cooling system). |
P.zonouz [ 05 янв 2014, 11:00 ] | |
RsM писал(а): I think you shouldn't install I7. Also it is very hot (think about cooling system). But it worked with i7, suddenly stop working, you just Eliminate the issue!! not solving!! |
unit1 [ 05 янв 2014, 17:32 ] | |
P.zonouz писал(а): Laptop not boot by Core i7 but boot and working ok by Core i3 did you write this? and after you wrote this P.zonouz писал(а): But it worked with i7 can you write more clearly? |
P.zonouz [ 05 янв 2014, 19:33 ] | |
unit1 писал(а): P.zonouz писал(а): Laptop not boot by Core i7 but boot and working ok by Core i3 did you write this? and after you wrote this P.zonouz писал(а): But it worked with i7 can you write more clearly? yes.I once sewed BIOS and boot by core i7. so after I assemble laptop there is no boot. and after that I tried more and more but not boot in core i7. So I changed CPU with core i3 --> booting!!! So now It boot with core i3 but not booting by core i7. |
P.zonouz [ 07 янв 2014, 13:10 ] | |
Заголовок сообщения: | Re: ASUS K43JA (K43JA) NOT BOOT BY CORE I7 CPU [РЕШЕНО] |
Problem solved. VGA resoled! laptop booted by core i3 because CPU have Integrated HD graphics but, And not booted by i7 because it has not Integrated HD graphics!!! So by solving VGA Chipset Disconnection by BGA machine every thing goes OK. |
