Текущее время: 27 апр 2024, 07:41
bomi123
Заголовок сообщения: Asus (X51RL rev. 2.1) after liquid Добавлено: 13 янв 2014, 23:30 |
Сообщения: 21 Откуда: Poland
At begin, laptop has not turn on. I have replace damaged elements, and correct paths, which i saw. After that, i get 3V and 5V. At now : after plug in DC jack current is growing up to 0,4A without pushing power on button.Graphics chip RC415ME is getting hot little extremely. After 10-15 sec. impossible to touch. I replace him whitch used another chip but nothing has change. Voltages appear at coils: 3V, 5V, 1,2V, and 19V on charger. After swich on, current is ~1A and grow to 1,3A. Power led lights and it's over. All measurement are on board with CPU and RAM.
gs84
Заголовок сообщения: Re: Asus (X51RL rev. 2.1) after liquid Добавлено: 18 янв 2014, 04:32 |
Зарегистрирован: 17 авг 2011, 01:50 Наличности на руках: 14.50
Сообщения: 1349 Откуда: 乌克兰
bomi123 писал(а): 3V, 5V, 1,2V, and 19V on charger. These not all voltages needed for starting mainboard. You need check all voltages on the coils. ---------------------------------------------------------- 3V, 5V, 1,2V, 19V - to nie wszystkie napięcia potrzebne do uruchomienia płyty głównej. Zmierz napięcia na wszystkich cewkach.
infosquadsn
Заголовок сообщения: Re: Asus (X51RL rev. 2.1) after liquid Добавлено: 09 фев 2014, 08:17 |
Зарегистрирован: 22 янв 2013, 06:12 Наличности на руках: 12.03
Сообщения: 18 Откуда: Argentina
bomi123 писал(а): That are all voltages. Im worried about 3V and 5V. They are little too high. I dont have the schematic right here but..... what about memory power supply ? usually works with 1.8 /1.5 and i didn't see these in your checklist. Don't worry so much about 3V and 5V, these lines are controlled by a IC that have so many "protections systems", if something is wrong the voltage is pulled down. Electronics is something inpredictible but i bet for a short in secondary lines
