HI First laptop had short circuit on one of it's voltage cores,damaged mosfets and shorted caps changed by similar one (k03b9 ->k0355 & k03d4 ->k0353).now system powers on but black screen. 2 cores would not generate(following mosfets are shorted and changed),There is physical damage on its core generator,but i couldn't recognize it coded by DJ-CA.Any schematic? Help about, plz.
orbit
Заголовок сообщения: Re: asusk50i (k40id rev.2.0) black screen
Добавлено: 07 апр 2014, 14:01
Зарегистрирован: 20 апр 2012, 10:57 Наличности на руках: 1,480.94 Сообщения: 1632 Откуда: Россия г. Санкт-Петербург
Вложение:
_________________ Ремонт ноутбуков Санкт-Петербург +79313406112 Ессентуки+79283151170
alifakhrniya
That is right. I bought RT8202a coded by DJ-DA and changed it,cores generated and problem solved,system boots up. Equivalent mosfets work well too. Thanks. Topic closed.
Сейчас этот форум просматривают: master3239, Zhuk и гости: 49
