Текущее время: 03 май 2024, 06:34
 Заголовок сообщения: Asus UX31A (VAZ21) Refuse to power on
СообщениеДобавлено: 29 май 2014, 02:11
Hello from Scotland!
Firstly. I'm sorry that I'm posting in English - your forum is the only place I've found via Google which has references to component level fault finding on laptop motherboards.
I also realise that I might not be 100% following the rules in asking this question - but I've attempted to use translation tools to read and understand the notes on new topics. I have searched for threads on the same topic and found one - viewtopic.php?f=40&t=17359 - except I'm not sure what a 'DAMP' bios means, and many other words aren't translating properly...
My issue is I have replaced a broken DC jack socket successfully on my UX31a however at the same time the laptop has stopped booting. I have tested the connectivity of the socket and 19V is showing up on the motherboard.
I can measure 1.8 Volts on the positive connector to the battery, so in my understanding the laptop is in a low power mode. When I press the power button nothing happens.
I would be able to flash the BIOS if people think that could be an issue. The laptop was left on after the DC socket was broken, so that the computer shutdown after the battery's charge was exhausted.
Can anyone offer some troubleshooting advice?
 Заголовок сообщения: Re: Asus UX31A (VAZ21) Refuse to power on
СообщениеДобавлено: 29 май 2014, 02:23
You must find the battery charger ic and find the pdf to it/
after that you have to measure the voltage before and after mosfets from adapter input.
СообщениеДобавлено: 29 май 2014, 03:11
Ok - that's the sort of advice I've been looking for! Thank you very much :)
I'll try and figure out where it is and will report back. Another option is that the keyboard connector is apparently not very strong on these laptops so I'll also investigate that and try and manually short the power on button pins.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Zenbook UX31A (UX31A.214) Взаимозаменяемость Wifi модуля Intel® Centrino® Advanced-N 6235
evoli
26 сен 2016, 10:36
meverik Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. UX31A (UX31A) ЗАМЕНА КРЫШКИ
zettabyte
14 июн 2016, 13:01
zettabyte Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ux31a (ux31a) перевернуть не родную камеру
fedottt
27 сен 2016, 15:02
fedottt Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ux31a (ux31a) нет изо
сергей петрович
11 апр 2018, 11:26
В этой теме нет новых непрочитанных сообщений. Asus UX31A (UX31A2 Rev. 2.0) Нужно прошить биос
КиссННД
12 сен 2015, 12:47
КиссННД Перейти к последнему сообщению
Сейчас этот форум просматривают: Algonk и гости: 41
