Asus X552C (Intel) No picture/image on lcd https://vlab.su/viewtopic.php?f=40&t=25857 |
FRD [ 30 окт 2014, 21:35 ] | |
Заголовок сообщения: | Asus X552C (Intel) No picture/image on lcd |
Hi A customer has brought an Asus X552C (x550CL Main Board Rev : 2.0) notebook which didn't have display on LCD but when connected to external monitor everything was fine, so I thought maybe the problem was with the GPU (N14M-GL-S-A2) cause after lifting the GPU completely from board the problem remained the same, I ordered a new GPU but unfortunately after soldering it the problem is the same. I can boot into windows on external monitor and on device manager there is only Intel HD Graphics 4000 and no sign of NVidia. Unfortunately could not find schematics and before ordering the chip I reballed it's own chip and also reflashed the bios but nothing changed. by the way Nvidia chip doesn't heat up even without heat sink installed. This is my first post so sorry if it's too long. |
and555 [ 04 ноя 2014, 13:22 ] | |
Заголовок сообщения: | Re: Asus X552C (Intel) No picture/image on lcd |
did you try another LCD?? |
FRD [ 04 ноя 2014, 18:28 ] | |
and555 писал(а): did you try another LCD?? No unfortunately I haven't one in hand, so I couldn't. Do you think because of LCD the nVidia chip will not work? |
notemaster [ 05 ноя 2014, 16:49 ] | |
Hi ! First you should try to check motherboard with new lcd cable. Sometimes this problem is of hybrid hm76. |
and555 [ 06 ноя 2014, 09:22 ] | |
FRD писал(а): Do you think because of LCD the nVidia chip will not work? yes, I ever experienced this on the asus A43S :) or you can try to reflash bios chip first. |
FRD [ 06 ноя 2014, 14:42 ] | |
notemaster писал(а): Hi ! First you should try to check motherboard with new lcd cable. Sometimes this problem is of hybrid hm76. Thanks for the reply, will try to test with a new LCD flat cable first. Regarding HM76 (NB is slj8e - HM76) do you think a reball is required or should I change the chip. Just to be clear with external monitor booted into windows, in device manager there isn't any sign of nVidia. Posted after 1 hour 10 minutes 36 seconds: and555 писал(а): FRD писал(а): Do you think because of LCD the nVidia chip will not work? yes, I ever experienced this on the asus A43S :) or you can try to reflash bios chip first. I have reflashed the BIOS, will try to test with a new LCD cable and let you know. By the way thanks. ;) |
