Текущее время: 21 сен 2024, 05:06
 Заголовок сообщения: Asus X552C (Intel) No picture/image on lcd
СообщениеДобавлено: 30 окт 2014, 21:35
Hi
A customer has brought an Asus X552C (x550CL Main Board Rev : 2.0) notebook which didn't have display on LCD but when connected to external monitor everything was fine, so I thought maybe the problem was with the GPU (N14M-GL-S-A2) cause after lifting the GPU completely from board the problem remained the same, I ordered a new GPU but unfortunately after soldering it the problem is the same. I can boot into windows on external monitor and on device manager there is only Intel HD Graphics 4000 and no sign of NVidia.
Unfortunately could not find schematics and before ordering the chip I reballed it's own chip and also reflashed the bios but nothing changed. by the way Nvidia chip doesn't heat up even without heat sink installed.
This is my first post so sorry if it's too long.
 Заголовок сообщения: Re: Asus X552C (Intel) No picture/image on lcd
СообщениеДобавлено: 04 ноя 2014, 13:22
did you try another LCD??
لا إله إلا الله محمد رسول الله
СообщениеДобавлено: 04 ноя 2014, 18:28
No unfortunately I haven't one in hand, so I couldn't. Do you think because of LCD the nVidia chip will not work?
СообщениеДобавлено: 05 ноя 2014, 16:49
Hi !
First you should try to check motherboard with new lcd cable. Sometimes this problem is of hybrid hm76.
СообщениеДобавлено: 06 ноя 2014, 09:22
yes, I ever experienced this on the asus A43S :)
or
you can try to reflash bios chip first.
СообщениеДобавлено: 06 ноя 2014, 14:42
notemaster писал(а):
Hi !
Thanks for the reply, will try to test with a new LCD flat cable first. Regarding HM76 (NB is slj8e - HM76) do you think a reball is required or should I change the chip. Just to be clear with external monitor booted into windows, in device manager there isn't any sign of nVidia.
Posted after 1 hour 10 minutes 36 seconds:
or
I have reflashed the BIOS, will try to test with a new LCD cable and let you know.
By the way thanks. ;)
В этой теме нет новых непрочитанных сообщений. Lenovo X230 (ldb-2 mb 11232-1) No picture on LCD after short with fan connector
derick
14 май 2020, 19:54
richk Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. tv plasma sony KDL-46ex725 image with black stripe at the top of the image
eletmoraes
06 сен 2017, 17:25
eletmoraes Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. tv LG 42PQ30R has image defect as attached image
в форуме PDP
eletmoraes
21 ноя 2019, 02:43
В этой теме нет новых непрочитанных сообщений. Asus N56V (N56VM Rev 2.3 ) No image in LCD
SpinNNN
10 мар 2017, 21:30
SpinNNN Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Clevo N850HJ (İntel) EC region picture need.
в форуме Clevo
CesurISLER
09 окт 2019, 06:50
Powerman Перейти к последнему сообщению
Сейчас этот форум просматривают: Google [Bot] и гости: 156
