N55S (Quanta nj5) no display https://vlab.su/viewtopic.php?f=40&t=26837 |
R EZ A [ 01 дек 2014, 18:48 ] | |
Заголовок сообщения: | N55S (Quanta nj5) no display |
hi all here i've a laptop that it turned on,but not show anything in display(lvds or D-sub) when i remove evrything(cpu,ram,vga) n plug dc jack,it turned on without press power buttun and use 0.4A,and power,charge and hdd led is on i find an object that its too hot ,thats it i remove it,but no change when i plug cpu,it use 0.9A and when i plug vga use 1.3A all volages are ok i programm bios replace cpu n ram but no change happened what should i do?! |
ruv [ 01 дек 2014, 19:13 ] | |
Заголовок сообщения: | Re: N55S (Quanta nj5) no display |
tc7sz08fu PLT_RST# |
R EZ A [ 06 дек 2014, 20:04 ] | |
i remove all parts (cpu,ram,vga,bios) and see that it use 0.1A i find that 5V is about 2V and lan ic(ar-8151) is warm next i remove 8151 , 5v back to normal and it working properly and i see display i hav new problem now when i press power buttun,it restart 3 time next boot up i program asm1042 flash ,but not change anything do u know any other reason that it not boot directly? |
R EZ A [ 10 дек 2014, 17:42 ] | |
any help? |
MSF113 [ 11 дек 2014, 00:41 ] | |
Usually 3 restart it's a problem with USB 3.0 controller or this controller firmware. |
R EZ A [ 15 дек 2014, 12:55 ] | |
reset problem solved by replace usb3 controller(asm1042) but i have new problem now:(( i can just use maximum a 2GB memory module if i put 2gb modules on each slot,it work and boot up but when install 2x1GB,2x2GB or 4g module,it use about 1.7A after some moments usage increase to 2.3A for some secends ,then restart |
R EZ A [ 17 дек 2014, 18:49 ] | |
any idea? |
R EZ A [ 22 дек 2014, 14:28 ] | |
Заголовок сообщения: | Re: N55S (Quanta nj5) no display [РЕШЕНО] |
it done with bios programing tnx all |
