x550d (x750dp rev:2.0) battery not charge https://vlab.su/viewtopic.php?f=40&t=38925 |
R EZ A [ 24 ноя 2015, 13:55 ] | |
Заголовок сообщения: | x550d (x750dp rev:2.0) battery not charge |
hi guys this laptop at first has turning on problem i replace bq24725 and it turned on but now it dont charge the battery in windows it show"0%,pluged in,charging" but no vlotage change on battery i replace charging mosfets but no change when just battery is pluged,laptop dont turn on with power key but when plug battery and ac,it turned on when press power key and when i remove ac,it stay on with battery with battery bq24751 vcc=14.5V regn=0 on ac regn=6 what do u think? |
R EZ A [ 26 ноя 2015, 18:26 ] | |
Заголовок сообщения: | Re: x550d (x750dp rev:2.0) battery not charge |
any idea? |
planetoxod [ 26 ноя 2015, 18:30 ] | |
Driving give. |
R EZ A [ 26 ноя 2015, 20:54 ] | |
what???!!!! |
planetoxod [ 26 ноя 2015, 22:45 ] | |
write in Russian, where the scheme? |
techgirl94 [ 27 ноя 2015, 02:40 ] | |
This guy had exactly the same problem, with the same laptop model: http://notebook-pro-center.ru/viewtopic.php?id=1005 He solved it by replacing charging controller (BQ24725A) and controller of second output key (IRF8707PBF) Use google translate to translate that thread above from Russian to English I hope that helps you |
krokozjbr [ 28 ноя 2015, 19:49 ] | |
ACIN_EC, EC_VDCBATOUT, IDCBATOUT? |
Jenuk [ 28 ноя 2015, 22:16 ] | |
check the Power MOSFET |
