x553ma (x553ma) NO POWER NO CHARGE NO LED WATER DAMAGED https://vlab.su/viewtopic.php?f=40&t=42221 |
phantomEVO [ 16 фев 2016, 01:52 ] | |
Заголовок сообщения: | x553ma (x553ma) NO POWER NO CHARGE NO LED WATER DAMAGED |
hi to all i'm ruben and i'm write from Sicily! I'm disperate! my laptop is dead after a glass of water fallen on it! i'm not an expert like you, but i would like to fix it. i've dismantled it and cleaned all with alcool. but the laptop is completely dead. i've no voltage on the power button. i've 1,7v on pin 4 of the battery and 0,80 on last two pins. i don't know a lot abut electronic, so this is the best i can do...could you suggest me something to help me ? please i've just used the search button and translated from your language to english and from english to italian, but i've not found anything interesting thank you Ruben |
bogivet [ 16 фев 2016, 02:22 ] | |
Заголовок сообщения: | Re: x553ma (x553ma) NO POWER NO CHARGE NO LED WATER DAMAGED |
That will be a hard job for you, because that is not so easy. First you need a circuits schematics for your laptop, and check all voltage on your motherboard. You need multimeter for check voltage. |
phantomEVO [ 16 фев 2016, 09:51 ] | |
thanks for your reply bogivet! i've a multimeter! the problem is that i can't find schematic diagrams! i've bought a document form a website, but there is "only" the board view... |
notemaster [ 18 фев 2016, 18:30 ] | |
there's no schematic for this platform yet :( |
phantomEVO [ 23 фев 2016, 19:49 ] | |
So impossible to fix? |
phantomEVO [ 26 фев 2016, 00:54 ] | |
Ok, so now i have 3,3 on power button, and 3,3v on pin 4,5,6, on the battery, than 0,50 on pin 7-8 the notebook is still dead no led no fan. what can i do? |
