N53S (N53SV Rev2.2) conversion:discrete to uma https://vlab.su/viewtopic.php?f=40&t=49435 |
simpleboy123 [ 08 авг 2016, 10:31 ] | |
Заголовок сообщения: | N53S (N53SV Rev2.2) conversion:discrete to uma |
Model:-N53SV Rev2.2 the is brought by customer,the problem is GPU has been died, need assistance for conversion respectively and don't hesitate to answer in your own language(i.e Russian...) but kindly use simple words so google translate can help. |
TSARIVAN [ 08 авг 2016, 23:02 ] | |
Заголовок сообщения: | Re: N53S (N53SV Rev2.2) conversion:discrete to uma |
У меня есть эта плата. Процессор Core i7 со встроенной графикой. Снять PL8500 и PL8501. |
simpleboy123 [ 09 авг 2016, 11:14 ] | |
thankx for your reply but only removing the two coils(PL8500 & PL8501)the m/b will be converted to UMA and start giving display? |
TSARIVAN [ 09 авг 2016, 11:17 ] | |
simpleboy123 писал(а): thankx for your reply but only removing the two coils(PL8500 & PL8501)the m/b will be converted to UMA and start giving display? Чем писать вот это, уже бы сняли и проверили. А ежели не верите, то зачем спрашивать. Пробуйте, у меня получилось. |
simpleboy123 [ 09 авг 2016, 11:26 ] | |
ok i am going to give it a try,give me some time than i will tell you. |
simpleboy123 [ 10 авг 2016, 14:25 ] | |
Beech return without repair because customer was in hurry. Special thankx to TSARIVAN. |
