Текущее время: 06 май 2024, 00:09
gs84
Заголовок сообщения: Re: F553MA (X553MA REV 2.0) NO AUDIO Добавлено: 20 окт 2016, 17:45 |
Сообщения: 1351 Откуда: 乌克兰
why you have closed this topic? https://www.elvikom.pl/asus-f553ma-no-audio-t46456.html Are you solved the problem? phantomEVO писал(а): i think that microphone is internal, because i've a single jack ... Not so, this is the double jack (mic and earphone), so that's why you need use special phones to check the audio output from jack. And I asked before: is the internal microphone is working?
gs84
Заголовок сообщения: Re: F553MA (X553MA REV 2.0) NO AUDIO Добавлено: 20 окт 2016, 19:54 |
phantomEVO писал(а): or you say to change another alc277? yes phantomEVO писал(а): i think the cpu is soldered! of course soldered, and you think what it can't be damaged?
