Текущее время: 28 мар 2024, 22:50
Страница 1 из 1 [ Сообщений: 24 ] |
gs84
Заголовок сообщения: Re: asus g750 (asus) shorting charger Добавлено: 17 фев 2017, 13:26 |
Зарегистрирован: 17 авг 2011, 01:50 Наличности на руках: 14.50
Сообщения: 1349 Откуда: 乌克兰
myth77 писал(а): i dont know how to test the motherboard without charger being plugged... you need to measure resistance relating ground at the input circuits
gs84
Заголовок сообщения: Re: asus g750 (asus) shorting charger Добавлено: 22 фев 2017, 23:57 |
myth77 писал(а): i shoud remove it and check resistence again on these part of the motherboard, without it attached? yes, do it myth77 писал(а): if yes, can you please explain why? I don't know how to explain you in few words, because you must know principles of input DC circuits in laptops.
myth77
Заголовок сообщения: Re: asus g750 (asus) shorting charger Добавлено: 23 фев 2017, 00:49 |
Зарегистрирован: 16 фев 2017, 18:48 Наличности на руках: 12.37
Сообщения: 130 Откуда: croatia
ok i remove it...but nothing...still continuity and resistence on all red parts of the motherboard except the other line 1 of this resistor (p_chg_path 19v). Although, the reading of the resistence on ac_bat_sys relating ground is now around 02.4 ohm. I even tried to put the charger/adapter to check but still shorting. Any suggestions on what to do next?
Also, regarding your second answer i believe i understand principles of dc input circuit..so..let me try for a noob, just a basics :)...From one part of the charger there is current coming through the motherboard with power of 19V, and regardles of the chip, cpu, graphic card...it uses the diods, capacitors, resistors, mosfets...to modify the current to lets say for example 5V cause the usb controller chip needs 5V (this is example)...the negative current is just part of the all current that is "coming back" to charger and so on but its needed so it can make complete circle... electricity coming one way and going other...In the end the negative current its just a part of the circle that connects motherboard in a big circle of power. The ground is something if needed (shorted) is used for taking electricity from the laptop-current to the ground...lets say in short circuits so it would not do any damage or so on :) Did this make any sense that i wrote? please if am wrong correct me? :) All other nets inside the motherboard are just separate connections from chips to lets say video card, audio card...and so on... So i figured that there is somewhere short in my motherboard that is connecting positive current to the ground because of some resistor or something else is broken. But, how to determine which one?
gs84
Заголовок сообщения: Re: asus g750 (asus) shorting charger Добавлено: 23 фев 2017, 17:56 |
myth77 писал(а): ok i remove it...but nothing what you mean? I asking about shorting at the resistor. After desoldering one shorting still before that resistor or after?
gs84
Заголовок сообщения: Re: asus g750 (asus) shorting charger Добавлено: 24 фев 2017, 14:59 |
myth77 писал(а): no, shorting only on 2. On 1 there is no resistence relating ground after desoldering... so, that's why problem in 19v circuits. How to determine shorting see here
gs84
Заголовок сообщения: Re: asus g750 (asus) shorting charger Добавлено: 26 фев 2017, 23:41 |
myth77 писал(а): Can i solder the wires od the toy on motherboard and put 4V battery and check where is heating? yes, you can. But how you will limit power consumption?
gs84
Заголовок сообщения: Re: asus g750 (asus) shorting charger Добавлено: 27 фев 2017, 21:12 |
myth77 писал(а): but will it be enough to test what part is heating? depend of the battery capacity
gs84
Заголовок сообщения: Re: asus g750 (asus) shorting charger Добавлено: 05 мар 2017, 00:59 |
myth77 писал(а): both wires (+ and -) on point 2? I tired to explain you elementary things. Before laptop repairing each must be know how to find a short on a PCB.
