Hey guys,
This laptop is killing me..
the laptop work in external VGA, but in LCD only lights up backlight. This laptop arrived with flat cable problem. At first I thought it was cable problem then i thought it was LCD problem (edid). However an equal laptop arrived and I tested both and remained the same.
i already change the PCH for new one. And after this when i put the ram 12800 Hz, the ram heats up.
But if i put the ram 10600 Hz it works the same as i say above.
I have seen some posts in this forum and I could not solve the problem yet.
any ideas for this problem?
Thank you
