Текущее время: 26 апр 2024, 22:14
desertearch
Заголовок сообщения: Re: x550cC (X550CC REV 2) no display Добавлено: 03 авг 2017, 00:10 |
Сообщения: 334 Откуда: West Side
ahkh_72 писал(а): Hi help needed Im working on Asus x550cc rev:2 matherboard. when press PWR BTM all signals (+5VAO +3VAO SLP_SUS 3VSUS_ON 5VSUS_ON +3,+5VO UNTIL PM_RSMRST) Present Except (AC_IN_OC & ME_AC_PRESENT).
I have tried reflashing the bios but still the same. Any help appreciated. Try to disable a onboard memory. Try - download/file.php?id=47465
_________________ You've only got three choices in life: Give up, give in, or give it all you've got.
desertearch
Заголовок сообщения: Re: x550cC (X550CC REV 2) no display Добавлено: 03 авг 2017, 11:36 |
ahkh_72 писал(а): thanks. but my mainboard does not have on board memmory. Posted after 15 minutes 30 seconds: when i power it on . it takes 12MA stable. i change the (south bridge- IO-charge PWM) but it is still the same az before(12ma). The best way to understand ,what is wrong is check the test points using repair guide. Try - download/file.php?id=58222Take a photo of your motherboard and release here, please.
desertearch
Заголовок сообщения: Re: x550cC (X550CC REV 2) no display Добавлено: 03 авг 2017, 16:56 |
ahkh_72 писал(а): which test point should i test? Download the guide- vlab.su/download/file.php?id=58222
desertearch
Заголовок сообщения: Re: x550cC (X550CC REV 2) no display Добавлено: 04 авг 2017, 21:24 |
ahkh_72 писал(а): I checked the test point. AC_IN_OC signal Is not present. where does AC_IN_OC comes frome? or what is wrong, that cause this problem? Cause battery is not connected. Write here all measurement's value what did you checked.
