The motherboard is burned because the charging pin was broken, and 19v rail touched A/D max pin (probably) and burned the IT8585vg. I was hoping that it is not the case, but when i replaced power socket (solder a new one) and plug the charger...nothing..the motherboard didnt show any signs of life. There is no boardview for g501 but there is for almoust the same n501jw..but the funny thing is that when i use multimeter and tried to check continuity between A/D MAX pin on power socket and one near the IT858VG chip there is no continuity? it shows resistence arround 1 kohm, how is this possible. Small O ohm resistor is connected to the ground but when i meassure from power socket A/D MAX and pin on this resistor there is no beep, no continuity...any ideas? and why is this pin connected to the ground with 0 ohm resistor? please explain somebody?
