asus (n501jw) non stop fan https://vlab.su/viewtopic.php?f=40&t=76115 |
omidhadian [ 20 май 2018, 08:51 ] | |
Заголовок сообщения: | asus (n501jw) non stop fan |
the case is a n501jw .when we start the laptop both fans start as laptop turns on and never stop rotating.i flashed the bios clear ME but nothing changed. also i cheked the heat bot every thing(cpu vga ...)was cool. any help ? |
alex01981 [ 20 май 2018, 14:51 ] | |
Заголовок сообщения: | Re: asus (n501jw) non stop fan |
1. See the tightness of the heat pipes. 2. The control chip of the fan. This is all provided that the dump was flashed with 100% correct. |
myth77 [ 21 май 2018, 15:19 ] | |
omidhadian писал(а): the case is a n501jw .when we start the laptop both fans start as laptop turns on and never stop rotating.i flashed the bios clear ME but nothing changed. also i cheked the heat bot every thing(cpu vga ...)was cool. any help ? so, you have picture on screen? if yes..check the temperatures on pch and memory/gpu memory modules. Btw how did you check the temperatures? |
