Заголовок сообщения: Dell (15R 5537 (LA-9981P)) No power
Добавлено: 20 ноя 2016, 13:06
Зарегистрирован: 26 май 2011, 10:13 Наличности на руках: 74.93 Сообщения: 17 Откуда: India
Hi all, I have dell 5537 la-9981p which have no power problem and B+ supply is 0.83V. There is no B+ supply generating from PU701 BQ717. I have replaced BQ717 but still there is no change in situation. Here is supply of BQ717. PIN 4 ACDRV = 19V PIN 6 ACDET = 2.5V PIN 5 AC OK = 3.5V PIN 20 VCC = 19V. B+ SUPPPLY is only 0.83V. kindly help me to solve the problem. Thanks
Ewwwgeny
Заголовок сообщения: Re: Dell (15R 5537 (LA-9981P)) No power
Добавлено: 20 ноя 2016, 14:18
Зарегистрирован: 08 июн 2016, 15:07 Наличности на руках: 1.00 Сообщения: 175 Откуда: Калининград
Check B+ on short circuit. Measure the resistance B+ to ground
atree2011
Добавлено: 21 ноя 2016, 13:21
There is no sorting. laptop is working on Battery. If charger is connected with battery it shows charging but battery is draining instead of charging.
MSF113
atree2011
Заголовок сообщения: Re: Dell (15R 5537 (LA-9981P)) No power [РЕШЕНО]
Добавлено: 21 ноя 2016, 17:28
Thanks MSF113..
There was problem in VIN mosfet. My problem has been solved after replacing the mosfet.
Сейчас этот форум просматривают: ISer, Ruslan-kam и гости: 7
