Текущее время: 02 июн 2024, 16:44
 Заголовок сообщения: Dell Latitude E5530 (LA-7902P REV:1) Do not display picture
СообщениеДобавлено: 19 мар 2022, 18:39
Hello everyone.
Laptop Dell Latitude E5530
Płyta: LA-7902P REV:1
KBC: MEC5055-LZY
Procesor: intel i3
The laptop turns on but does not display the picture, after pressing the power button fan does not spin, the motherboard is stuck at 600mA current consumption the CPU and PCH chip gets warm. When I press again power button the fan start to spin but after a couple of seconds the motherboard turns off itself and current consumption drops to 12mA. The motherboard correctly displays fault codes because if I turn on the motherboard without RAM memory the LED faults code indicates the ram memory is missing. I replaced the CPU and RAM memory, no changes in the motherboard behavior. I reflashed BIOS and EC chips U53 and U52 (the U52 chip was damaged I had to replace it), reflash KBC chip, all without a positive result. The measurement I took from the motherboard is below. Please for advice where could be the issue.
PL100 -25MΩ motherboard turned on voltage 19.5V
PL103 -35kΩ motherboard turned on voltage 5V
PL101 -7KΩ motherboard turned on voltage 3,3V
PL301 -360Ω motherboard turned on voltage 1,8V
PL400 -100Ω motherboard turned on voltage 1,05
PL500 -26Ω motherboard turned on voltage 1.07V
PL200 -1KΩ motherboard turned on voltage 1,5V
PL15 -24Ω motherboard turned on voltage 0,9V
PL702 -7Ω motherboard turned on voltage 0,876V
PL703 -7Ω motherboard turned on voltage 0,876V
PL704 -4Ω motherboard turned on voltage 0V
PL1300-330KΩ motherboard turned voltage on 19,5V
PL1301 -7MΩ motherboard turned voltage on 0V
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Latitude E5530 (LA-7902P) отключение с разными интервалами после нажатия на кнопку питания
в форуме Dell
sattrister
06 фев 2023, 21:45
sattrister Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell E5530 (LA-7902P) предположительно ME регион
в форуме Dell
ulyanoff
23
4178
31 дек 2019, 00:56
В этой теме нет новых непрочитанных сообщений. Lenovo B590 (Intel) Lenovo B590 power on but no display (picture)
cygron
28 июн 2021, 09:32
kkv Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. dell E5530 (LA-7209P) изменить service tag
в форуме Dell
djkomix
18 мар 2016, 13:46
В этой теме нет новых непрочитанных сообщений. Dell E5530 (LA-7904P) Не видит сетевую карту
в форуме Dell
Carbon_100
15 май 2023, 13:58
vzrivpaket Перейти к последнему сообщению
