Текущее время: 25 апр 2024, 06:02
 Заголовок сообщения: Dell D430 (LA-3741P) Fan not spinning and no display
СообщениеДобавлено: 10 июл 2020, 15:50
Hello! Need urgent help P.S !
Fixed initially a short on memory bus +1.8V rail by removing on board cells getting hot one by one, till last cell.
Inserted a DDR2 in SODIMM slot1.
Switched lap, all main voltages are ok, but fan and display are failing.
Voltages measured on FAN & Thermal Sensor IC "EMC4000" are attached.
Issues found :
Pin6- FAN_OUT : 0V ?? no spinning.
Pin30- THERMTRIP_SIO : 0V low, I guess, it should be high i.e +3.3V p.s correct.
Pin29- HW_LOCK# : 0V. Is it Hardware lock signal ? Should it be high level i.e +3.3V ? p.s correct.
Any idea on next steps to help solving issues would be much appreciated!
Thank you
 Заголовок сообщения: Re: Dell D430 (LA-3741P) Fan not spinning and no display
СообщениеДобавлено: 12 июл 2020, 16:35
Still waiting for any suggestion from the 114 viewers.
СообщениеДобавлено: 12 июл 2020, 23:57
A Dell´s fan starts at a processor temperature above 60 degrees Celsius.
Всё очень просто - если знаешь как...
СообщениеДобавлено: 13 июл 2020, 02:06
Forget to add : when laptop is switched, power led lights for 45" and then off. CPU temperature went high but fan didn't spin.
Also, though, I supplied pin1 of JFAN1 "+FAN1_VOUT" directly with 3.3v run, laptop always went off after 45".
Found pin29 "HW_LOCK #"= 0V.
Wish to know if "HW_LOCK #" is Hardware lock signal?
Should it be by default high level ie + 3.3V???
Thank you for following up.
СообщениеДобавлено: 01 авг 2020, 22:30
Surprised not to get any new suggestion from viewers.
Once assembled, noticed that 2 leds were constantly blinking, when laptop is on (onboard memory fail).
Didn't find any way to make bios bypass checking the onboard DDR and move directly to the SODIMM slot1.
Laptop was returned to customer. Thread is considered closed.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. d430 (LA-3741P) Определение типа адаптера
в форуме Dell
kvadriga
07 окт 2017, 02:11
kvadriga Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell XPS L502x (dagm6cmb8d) Fan constantly spinning full speed black screen
в форуме Dell
scobay
09 янв 2019, 19:24
scobay Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell 17r (da0r03mb6e0) Fan constantly spinning full speed
в форуме Dell
scobay
11 дек 2018, 03:23
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. hp 8440 (fan not spin ) fan not spin in battery mode
rajeshkumar
26 авг 2016, 12:32
rajeshkumar Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toshiba C50-B (da0blimb6f0 rev: f) No display and unit turns itself on, fan ot working properly Cpu gets hot
в форуме Toshiba
scobay
20 апр 2015, 14:57
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 24
