Текущее время: 22 май 2024, 03:42
 Заголовок сообщения: XPS 13 9370 (Compal LA-E671P) Problem with charge connected before load windows after replacing processor
СообщениеДобавлено: 10 мар 2023, 05:34
Hi all.
I have 2 boards of Dell XPS 13 9370 (Compal LA-E671P) that had a same problem after replacing processor.
Their run perfectly on battery, but had problem when it connected to USB-C PD charger before load windows.
If I connect a charger when the laptop was off, then I tried to turn on, their had bootloop. Only show Dell Splash Screen, and restarted.
Cannot load windows, cannot load Dell diagnostic, but can enter bios.
If I removed a charger (only batteries), turn on, it can load windows or can load Dell diagnostic perfectly.
In windows, if I connect a charger, it can charge the batteries to 100%, no show error.
1st Board :
Came originally with the laptop that have random BSOD on windows especially "Watchdog..". Check RAM with memtest86, all passed. Had no error with charger. It can load windows with/without charger.
So I decided to replace the i7-8550U (SR3LC) processor. After replacement, I flashed clear ME BIOS, set BG to 0, and get the problem with charger connected before windows load.
2nd Board :
Board that I bought on Ali. Came with i3-8130u (SR3W0) processor. When it's arrived, I had checked everything, of course the charging too, it's 100% normal. Had no error with charger. It can load windows with/without charger.
I deciced to try to replace the i3-8130u (SR3W0) to i7-8550U (SR3LA) processor (another processor, not same processor that I plant on 1st board).
After replacement, I flashed clear ME BIOS, set BG to 0, and get the problem with charger connected before windows load (same problem as the 1st board).
Donor Processor for 1st Board it came from Lenovo Yoga 730-13IKB (Compal LA-F571P, checked BG = 0)
Donor Processor for 2nd Board it came from Lenovo Yoga 720-13IKB (Compal LA-E551P, checked BG = 0)
Is there must a special treatment after replacing processor for this board??
В этой теме нет новых непрочитанных сообщений. DELL SPX13 9370 (LA-E671p CAZ60) нет изображения
в форуме Dell
sergun
1150
22 авг 2022, 21:25
sergun Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. dell (vostro1310(vga intel)) black screen before windows loading
в форуме Dell
nasser_pczone
30 июн 2015, 16:21
s0ulbl4d3 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell XPS 13 9379 (CAZ60 LA-E671P) Напряжение +VCCGT не появляется.
в форуме Dell
user54321
1352
05 окт 2022, 13:13
user54321 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell XPS 13 (CAZ60 LA-E671P rev 1.0) Тусклая подсветка экрана
в форуме Dell
elektrorepair
07 сен 2023, 20:11
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba Satellite-L50 (DA0BLIMB6F0 Rev.F) hangs before boot (post)
в форуме Toshiba
andromedax
5585
01 дек 2019, 20:04
stefanbs Перейти к последнему сообщению
