Заголовок сообщения: Dell (DELL_Vostro_1320_-_COMPAL_LA-4232P_KAL80_-_REV_1.0) white screen
Добавлено: 03 дек 2013, 15:12
Зарегистрирован: 18 фев 2012, 22:42 Наличности на руках: 118.34 Сообщения: 389 Откуда: Brasil
Hello guys okay? I have a dell laptop 1320, is showing a white screen on the LCD Monitor and in the normal external I've tested the cable plan in continuity mode is OK, put another screen to see but same problem. Tested output LCD PJ4 after testing.
- PINS: 1 and 2 - 3.3V WITHOUT PLANNING AND CAI P / 2.2 when placed SCREEN 3, 4 and 5 ---> 3.3V 6 -> 2 V 7 -> 1.3V 8 -> 3.3 24, 25 -> 3.3 28 -> 5V 33, 36 -> 19V 35 -> 3.3
The plate is as follows DELL_Vostro_1320_-_COMPAL_LA-4232P_KAL80_-_REV_1.0
Even so I'm thinking it may be the screen if someone can check with the tests I conducted, it is OK to leave lcd, I am grateful.
Thank you, hugs.
Sergej
Заголовок сообщения: Re: Dell (DELL_Vostro_1320_-_COMPAL_LA-4232P_KAL80_-_REV_1.0) white screen
Сейчас этот форум просматривают: SchneiderSoft и гости: 27
