P.zonouz писал(а):
How knows why background goes pink and how to fix it?
It could be a issue in the screen conector. Lack of a RGB channel could cause this effect.
Doc писал(а):
Yes. Trouble with contacts between crystal and chip substrate. After reballing (high temperature) contacts are restoring for a short time.... usually a few weeks.
Yes, totally agree. In some cases you will see some strange effects after reball, like high VGA temperature, this will indicates that the failure is inminent.
