Текущее время: 08 май 2024, 16:25
 Заголовок сообщения: Hitachi LCD Vostro1520 (TX39D89VC1FAA ) Background is pink
СообщениеДобавлено: 12 янв 2014, 10:21
Hi.
Dell Vostro 5120 brought for Not booting Problem(with LCD 15.4" Hitachi TX39D89VC1FAA assembled) after problem solved( Reballing 630-U2) now we have display but background is Pink, LCD tested on other one and Still pink!!, another LCD assembled on Laptop and display is fine. How knows why background goes pink and how to fix it?
Don't give up without the fight.
 Заголовок сообщения: Re: Hitachi LCD Vostro1520 (TX39D89VC1FAA ) Background is pink
СообщениеДобавлено: 12 янв 2014, 13:17
CCFL lamp dies
PS
>Reballing 630-U2
it doesn`t repair
СообщениеДобавлено: 12 янв 2014, 14:23
Doc писал(а):
>Reballing 630-U2
it doesn`t repair
U mean Can not repair 630-U2 by rebelling?
СообщениеДобавлено: 12 янв 2014, 15:40
Yes. Trouble with contacts between crystal and chip substrate. After reballing (high temperature) contacts are restoring for a short time.... usually a few weeks.
in this case need check lamp in display and change lamp/display
СообщениеДобавлено: 14 янв 2014, 07:45
It could be a issue in the screen conector. Lack of a RGB channel could cause this effect.
Yes, totally agree. In some cases you will see some strange effects after reball, like high VGA temperature, this will indicates that the failure is inminent.
СообщениеДобавлено: 18 янв 2014, 11:11
after changing Flour-cent Lamp nothing changed.
СообщениеДобавлено: 18 янв 2014, 20:18
As I understood early message ("LCD tested on other one and Still pink!!, another LCD assembled on Laptop and display is fine") the other LCD screen works fine on this laptop.
Change screen? It`s easier ) If not - check resistance LVDS pairs (screen connector: pins 8,9,11,12,14,15), must be same, "update" edid
СообщениеДобавлено: 26 янв 2014, 09:34
Problem from LCD Board. SO it is better to renew whole LCD.
В этой теме нет новых непрочитанных сообщений. Продам корпус samsung 535U NP535U3C (PINK)
rks
25 мар 2018, 13:12
rks Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. asus x55a ( ASUS X55A rev 2.2) light pink color on screen
bokin021
12 сен 2020, 17:20
bokin021 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Делим тач от LCD и иные операции по разделению модулей тач+LCD (или тач от крупуса)
DimonNT
14663
22 мар 2015, 17:01
В этой теме нет новых непрочитанных сообщений. tv lcd lg 32LB580B телевизор lcd lg 32LB580B Логотип LG заблокирован в центре экрана команда не принята
в форуме LCD
eletmoraes
16 сен 2019, 18:30
Bert46 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Hitachi терминал?
vasilr007
5813
30 июн 2014, 20:27
Толстый2 Перейти к последнему сообщению
Сейчас этот форум просматривают: AsW.cfg.31r и гости: 20
