Текущее время: 20 апр 2024, 05:30
 Заголовок сообщения: Inspiron 3521 (LA-9104P) No Display 4 Beeps  [РЕШЕНО]
СообщениеДобавлено: 07 июл 2014, 14:51
Hi, A customer brought me this laptop Dell Inspiron 3521 (LA-9104P) which isn't power on properly.
When I push power button lights on and indicate 4 beeps in 3 times. (Beep-Beep-Beep-Beep) X 3.
According to the Dell service manual it says this beep codes indicated Bad memory. But I have changed RAM cards and problem is still there.
Is it something relating to the BIOS ? or something else. Bcz I couldn't find any solution from anywhere for this 4 Beeps error.
When I take out RAM cards and turn on the laptop , power lights on and shut down immediately.
 ! MSF113 писал(а):
Don't attach schematics at post, when it is on the forum.
 Заголовок сообщения: Re: Inspiron 3521 (LA-9104P) No Display 4 Beeps
СообщениеДобавлено: 08 июл 2014, 19:53
Anyone? plz help me on this matter.
СообщениеДобавлено: 09 июл 2014, 08:44
Модератор
Модератор
Участник АСЦ
Участник АСЦ
Reflash BIOS, check RAM voltages, replace processor.
booknot.ru тел (343)237-37-37
СообщениеДобавлено: 09 июл 2014, 14:31
RAM voltages are ok and I have already Flash the Main ROM but i Couldn't flash the EC inside the kb 9012 Bcz i dont have an apropriate tool for that.
When i pull the Ram it gives 2 beep codes for " No RAM module in the socket" error. but when i Put a new RAM again its beeping. I found that 4 Beeps indicates "Memory read/write failure" according to the Dell Beep codes for Inspiron. Is this relating to the PCH?
СообщениеДобавлено: 22 авг 2014, 11:07
I replaced the south bridge and everything works fine now. I think earlier chipset didn't receive memory readings properly. Thanks
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Inspiron 3521 (LA9104P) 4 сигнала (beeps)
в форуме Dell
mishka007-84
24 ноя 2017, 17:41
mishka007-84 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. dell 3521 (Display problem help me) Display problem
в форуме Dell
ahmeterengul
12 июн 2017, 11:22
ahmeterengul Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. dell 3521 (vaw00 la-9104p rev 1.0 a00) the screen does not display
в форуме Dell
Ceyhun66
10 ноя 2018, 02:10
Chazy-Chaz Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Inspiron 3521 (Compal La-9104P Rev1.0) Подскажите номиналы резисторов
в форуме Dell
pbls
09 июн 2014, 11:21
pbls Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Inspiron 3521 (La-9104P) Выключается сам по себе
в форуме Dell
Henkok_UA
12
7326
24 сен 2014, 15:49
kerim92 Перейти к последнему сообщению
