Текущее время: 29 мар 2024, 04:24
latitude
Заголовок сообщения: Dell M5030 (Wistron DJ2 48.4em18.011) Power led lights, can't power on Добавлено: 09 май 2015, 18:52 |
Сообщения: 67 Откуда: Bulgaria
Hi guys, we have a little situation here :) There is Dell Inspiron M5030 on the desk. Mobo is Wistron DJ2 48.4em18.011 Problem - when insert main battery or adapter, power led (led in the power button) lights and notebook doesn't power on. All the times, when I have this, problem was in the multicontroller (in this case NUVOTON NPCE781BA0DX). So, I replace the multicontroller, but problem exist. 3.3 and 5 volts present. 3.3v on bios also. I try something else, which make me wonder - remove main and rtc battery and plug only power adapter. Notebook powers on by itself, post, and continue with OS loading. Notebook works till shutdown. After shutdown, power button led lights, and notebook doesn't start.. So I have to remove power adapter again.. Does anybody have such problem?
Thanks in advance.
andromedax
Заголовок сообщения: Re: Dell M5030 (Wistron DJ2 48.4em18.011) Power led lights, can't power on Добавлено: 10 май 2015, 00:29 |
Сообщения: 262 Откуда: Alicante, Spain
latitude писал(а): Hi guys, we have a little situation here :) There is Dell Inspiron M5030 on the desk. Mobo is Wistron DJ2 48.4em18.011 Problem - when insert main battery or adapter, power led (led in the power button) lights and notebook doesn't power on. All the times, when I have this, problem was in the multicontroller (in this case NUVOTON NPCE781BA0DX). So, I replace the multicontroller, but problem exist. 3.3 and 5 volts present. 3.3v on bios also. I try something else, which make me wonder - remove main and rtc battery and plug only power adapter. Notebook powers on by itself, post, and continue with OS loading. Notebook works till shutdown. After shutdown, power button led lights, and notebook doesn't start.. So I have to remove power adapter again.. Does anybody have such problem?
Thanks in advance. Try to reprogram bios chip. Linnk to bios dump: download/file.php?id=42868
