Текущее время: 26 апр 2024, 23:26
 Заголовок сообщения: Dell XPS 15 9530 (VAUB0 LA-9941P) Failed BIOS update
СообщениеДобавлено: 22 сен 2015, 21:56
Hello,
Got this machine from a client, he tried to update the bios via windows from A08 to A09. After the machine restarted, the screen went blank and the power button can't switch it on. Only connecting the DC charger then pressing the right arrow key can. I tried to recover its bios using the VAUB0A09.ROM and VAUB0A09.HDR files, it did display the dell logo and does perform the boot flash process successfully but when it restarts again no display. ANY HELP WILL BE APPRECIATED.
Regards.
 Заголовок сообщения: Re: Dell XPS 15 9530 (VAUB0 LA-9941P) Failed BIOS update
СообщениеДобавлено: 22 сен 2015, 23:31
Did you try this bios? viewtopic.php?f=41&t=7412&p=192461&hilit=*9941p*#p192461
В личке все ответы платные.
СообщениеДобавлено: 23 сен 2015, 22:55
gofer писал(а):
Yes i did, but it did not work.
СообщениеДобавлено: 23 сен 2015, 23:10
Try this.
СообщениеДобавлено: 01 ноя 2015, 11:36
gofer писал(а):
Try this.
The client had sent the machine to us warranty but the quoted repair cost was too expensive. So when I get it back, I will try and let you know how it goes.
Regards.
СообщениеДобавлено: 02 ноя 2015, 09:17
bridx писал(а):
gofer писал(а):
Try this.
Regards.
I did try; With your dump it still doesn't power up via the power button but whenever i do the bios recovery with the A08 file it displays the dell logo the proceeds to do the bios flash process. After finishing it turns off and cannot turn on again. Anyone know how i can flash the EC?
Regards.
Posted after 7 minutes 34 seconds:
bridx писал(а):
bridx писал(а):
gofer писал(а):
Try this.
Regards.
Regards.
Its EC is ENE KB9012BF A4 N-3X1744 PCA140108 BGA
В этой теме нет новых непрочитанных сообщений. dell xps 9530 ( LA-9941P) bios update failled
в форуме Dell
lanfrey
28 сен 2019, 11:08
В этой теме нет новых непрочитанных сообщений. dell xps 9530 (compal la-9941p) нет старта после обновления bios
в форуме Dell
igorbelarus
28 мар 2021, 17:14
DeathBringer Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell XPS 9530 (Compal LA-9941P) Проблеми с биосом
в форуме Dell
slizik
30 янв 2017, 19:30
RebuS_ Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell M3800 (VAUB0 LA-9941P) залитик
в форуме Dell
psyjamm
1950
10 окт 2018, 00:50
psyjamm Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Aspire 5742G (LA-5891P) me fe update failed, please try again после замены HM55
Saiberex
2830
07 июл 2014, 10:41
orbit Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 31
