Текущее время: 25 апр 2024, 17:43
 Заголовок сообщения: Dell Latitude D531 laptop problem
СообщениеДобавлено: 22 сен 2011, 15:48
When running on battery displays the following message-
The computer is docked and only battery power is detected. this can happen if the power adapter is missing, the power cord is unplugged, or the computer is not properly connected to the docking station. you should undock, redock, attach the power adapter, or plug in the power cord.
Strike the F1 key to shutdown.
Im not using the docking procedure
When turned on the power supply is working properly. may be a malfuction on the motherboard?
 Заголовок сообщения: Re: Dell Latitude D531 laptop problem
СообщениеДобавлено: 22 сен 2011, 22:23
What is the voltage at 17 pin U4 (PI3L500)?
СообщениеДобавлено: 25 сен 2011, 20:49
Hello,
I completely took the laptop apart and I plug on the motherboard just the HDD, Display and the RAM just for a quick check. After powering the system up, all started fine without any errors.
Shut it down and then I attached the modem module start all back up…all OK.
Shut it down and I attached the Wireless module, started but with an error. Took it out…all OK, put back the module back in …will not work.
I took off the wires from the module and started back up….it worked, I reconnected the wires back up and since then it works fine.
I do not understand where or what the problem was.
Thank You.
СообщениеДобавлено: 27 сен 2011, 01:22
i think your wireles module socket was dirty.
wash it with solvent.
СообщениеДобавлено: 21 окт 2011, 16:15
Вы проверить зарядное устройство раздел на материнской плате?
В этой теме нет новых непрочитанных сообщений. Dell D531 (jx6) Отсутствует напряжение +1.2v_ALW_SUS
в форуме Dell
AndVas
24
2094
19 июн 2019, 07:40
AndVas Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. dell 3521 (Display problem help me) Display problem
в форуме Dell
ahmeterengul
12 июн 2017, 11:22
ahmeterengul Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. program for download any bios from the laptop without opening the laptop
в форуме Программное обеспечение | Software
momo1
15 сен 2015, 17:50
В этой теме нет новых непрочитанных сообщений. OMEN HP Laptop (Quanta G35D) +VCCGT problem
andromedax
03 янв 2020, 21:37
andromedax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Xiaomi Gaming Laptop i7 7700hq Motherboard Problem (DA0TMAMBAC0 REV:C)
в форуме Xiaomi
enes
18 фев 2022, 11:49
enes Перейти к последнему сообщению
Сейчас этот форум просматривают: Синтез, senseyoo7, ДимаМИР и гости: 20
