Заголовок сообщения: N5010 (DG15 48.4HH01.011) NO POWER
Добавлено: 08 июл 2016, 16:07
Зарегистрирован: 04 апр 2014, 20:52 Наличности на руках: 15.09 Сообщения: 70 Откуда: Sri Lanka
It's a N5010 DG15 discreet (ATI GPU) laptop and no power.
01. 3.3v and 5v available (TPS51125) - OK 02. +5V_ALW, +3.3V_ALW, +15V_ALW 03. 3V_5V_POK = 3.3v AC_PRESENT_EC=3.3v 04. KBC_PWRBTN_EC#= 3.3v to 0v (when pressed power button) 05. PM_PWRBTN#= 0v to 3.3v (when press power button) 06. PM_SLP_S4# , PM_SLP_S3# ,+5V_RUN , +3.3V_RUN , +1.5V_RUN = All these power lines power on and off (again and again looping) 07. No LED lights turn on. 08. No charging LED on but battery charging.
So far I have changed TPS51125 and EC NPCE781BAODX, flashes U6201 (4Mb BIOS). Nothing changed. What might be the problem....? Where to start? Please help
protos
Заголовок сообщения: Re: N5010 (DG15 48.4HH01.011) NO POWER
Добавлено: 08 июл 2016, 18:36
Зарегистрирован: 09 янв 2014, 22:11 Наличности на руках: 76.02 Сообщения: 41 Откуда: UA
detect termal or error pin to NPCE781
kandyan
Добавлено: 08 июл 2016, 21:04
I have already checked them. pin 99 = 3.3v pin 96 = 3.3v pin 106 = 0v to 3.5v, 2.4v (it changed 0v to 3.5v and again 0v. after few seconds again it shows 3.5 or 2.4 v) pin 95 = 3.3v pin 6 3.3v
kandyan
Добавлено: 09 июл 2016, 08:20
I also checked U3901 (thermal controller) and Q3904 which is switching hardware pure shutdown. both works fine. THERMTRIP#= 0v and PURE_HW_SHUTDOWN#= 3.3v
