Текущее время: 20 апр 2024, 07:38
and555
Заголовок сообщения: Re: Dell Inspirion 5437 (D0e40-Hsw ddr3 12314-1) no power , Totally dead Добавлено: 24 май 2017, 15:27 |
Зарегистрирован: 10 апр 2012, 22:42 Наличности на руках: 86.09
Сообщения: 285 Откуда: Indonesia
eletmoraes писал(а): Is the defect not in the PU4503 itself? It can be, but the easiest way to find the defect component, just apply a power supply from external source to it, and find component that get hot. And please don't apply a voltage more than it would be.
_________________ لا إله إلا الله محمد رسول الله
and555
Заголовок сообщения: Re: Dell Inspirion 5437 (D0e40-Hsw ddr3 12314-1) no power , Totally dead Добавлено: 06 сен 2017, 11:00 |
eletmoraes писал(а): What can burn of components if, instead of 5v, use a 12v power supply between pins 8 of the PU4101 and GND? Oww, a lot of components will be burnt if you apply 12v. For the safety, I usually use 1v - 3v, it will be enough. eletmoraes писал(а): Could it be just the NCP81172 and the RT8237EZQW? No, I think there are others.
