Заголовок сообщения: notebook dell vostro 3500 (Dell Vostro 3500 056tk2 10865) heats up and turns off after a few seconds
Добавлено: 28 апр 2018, 02:11
Зарегистрирован: 18 фев 2012, 22:42 Наличности на руках: 118.34 Сообщения: 389 Откуда: Brasil
The first test I did was to examine the cooler, it was when I concluded that the cooler was defective (need to change it). After replacing the cooler I noticed that the CI U2001 had a heating that I do not know if it is normal or not.
how can I know if the component is good or not? This notebook does not exist the CI (GPU) although in the copper sink have an area for heat dissipation. It may be that simply replacing the cooler solves the problem of shutting down the machine
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 19
