N5010 (DG15) WaterDamage/no display https://vlab.su/viewtopic.php?f=41&t=78900 |
R EZ A [ 02 авг 2018, 19:56 ] | |
Заголовок сообщения: | N5010 (DG15) WaterDamage/no display |
hi guys i have a laptop here that it had water damage and didnt turn on water damage was on PU4601 and pu4701 area i repair some damages that i find and now it turns on when i plug ac,use 1.5A but no display when i hold pwrbtn it didnt turn off 3.3&5V is good cpu_vcc is good diffrent ram & cpu tested but no change i replace kbc but didnt change what's your idea? |
myth77 [ 03 авг 2018, 13:00 ] | |
Заголовок сообщения: | Re: N5010 (DG15) WaterDamage/no display |
Did you try other bios dumps? |
R EZ A [ 03 авг 2018, 21:39 ] | |
yes i did |
PussyMonsta [ 04 авг 2018, 11:53 ] | |
R EZ A Is there all power voltage present and good value?Are you try to connect post card? |
R EZ A [ 04 авг 2018, 18:42 ] | |
yes voltages and good values are ok post card code is 05da 1614 |
