Заголовок сообщения: NP530U3C (Lotus-13) Dont work iSSD
Добавлено: 23 янв 2022, 19:48
Зарегистрирован: 23 янв 2022, 19:30 Наличности на руках: 14.01 Сообщения: 9 Откуда: Porto Alegre / Brasil
Hello. This is my first post here and I want to compart a case Im working now.
This machine dont accept any command on iSSD (Sandisk i100 24GB) to recover.
When I boot with Strelec WINPE, we can see 24G disk, but only raw.
I already try: - Diskpart --> read normally, but when tried CLEAN, DELETE or CREATE any volume, process fail and disk disapear from the list, needed reboot. - EASEuS --> cant read any information from this chip, and desapear after every try, needed to reboot to see drive again.
Im thinking in change this BGA169 chip to a 256GB, but dont have certain about compatibility between BGA169 and BGA153. Only found BGA153 offers.
You think if I make a reflow on this chip I can recover this to work or only change will be necessary?
Thanks a lot for any help/tip
_________________ __________________ Estudier Porto Alegre / Brazil
REM
Заголовок сообщения: Re: NP530U3C (Lotus-13) Dont work iSSD
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 22
