Текущее время: 28 апр 2024, 15:30
 Заголовок сообщения: samsung (np450r5e) battery not charging
СообщениеДобавлено: 09 май 2022, 21:29
samsung np450r5e motherboard ba41 02244a problem battery is not charging, battery is empty and battery replaced but it isnt fixx th problem ı tried everything with software operation or out and in tactics but nothing helps. ı have 20 pins charger IC ı think bq24735
how will ı go ahead from there.? ı dont have schematic. ı controled bq24735 cmsrc 1.9 v acdrv 1.9 and acok signal is sometimes 8.8v sometimes 1.3v is the problem bq24735 ?
 Заголовок сообщения: Re: samsung (np450r5e) battery not charging
СообщениеДобавлено: 09 май 2022, 21:46
1nteger
Hi, check your mail. Acok should be 3.3v
---------- Добавлено спустя 9 минут 57 секунд: ----------
Acfet and Rbfet are close
Sorry for my english)))
СообщениеДобавлено: 09 май 2022, 22:33
thanks for answer. ı am the beginner for the repair. are they input fets ? ı dont have schematic. please pm me schematics about ba41 02244a
sorry for waiting 1 hours ım new member and ı cant download anything.
СообщениеДобавлено: 09 май 2022, 23:05
Yes they are the inputs fets, they name on schema are tr562 and tr554, then they are close, laptop doesn't turn on, not just no charging battery, send to your mail the second file
СообщениеДобавлено: 09 май 2022, 23:37
okay friend thanks. ı checked and ı answer to you on mail pls check your mail and spam folder too
ı checked there is short on two mosfets ı will upgrade later this subject. anyone has the pcb diagram on this motherboard ramos_14
Posted after 1 hour 10 minutes 58 seconds:
laptop turning on with ac adapter. there is no problem laptop works fine with ac adapter. but not charge adapter and plug in but not charging fault. any others help for me ?
СообщениеДобавлено: 10 май 2022, 09:35
First what you must do, is checking your battery in another working laptop, or check another battery in your laptop. Then if all will be not ok, you shold wright here the measurements of all pins bq24735 when battery is connected, and we together will thinking what is the problem
Sent boardview
---------- Добавлено спустя 11 минут 29 секунд: ----------
That is the problem, you need to fix this
В этой теме нет новых непрочитанных сообщений. E5-571 (LA-B161P) not charging not switch with battery
erdi34
06 окт 2018, 20:25
t.tashbaev Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Samsung NP550P (MACLAREN REV:1.2) Not Charging Battery
в форуме Samsung
abuholm
24 сен 2014, 23:56
abuholm Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Samsung NP355V5C (LA-8863P rev:1.0) Battery not charging
в форуме Samsung
Djosla
03 мар 2017, 23:23
John07 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP PAVILION 15-P214DX (DAY11AMB6E0) Battery not Charging
abuholm
08 мар 2016, 02:46
ars44 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toshiba C50-a-19u (Pegatro PT10f) Battery not charging
в форуме Toshiba
scobay
15 июн 2017, 20:21
maverikdj Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 26
