ultrabook samsung (lotus 13 ba41-02040A) NO CHARGER BATTE https://vlab.su/viewtopic.php?f=42&t=72418 |
eletmoraes [ 21 фев 2018, 02:16 ] | |
Заголовок сообщения: | ultrabook samsung (lotus 13 ba41-02040A) NO CHARGER BATTE |
ultrabook samsung model: np530uc3-ad5br not charge battery. The owner of the ultrabook samsung bought a new battery without being sure if the problem was in it. The battery he bought has as specification: Model: CS-SNP530NB PART N: AA-PBYN4AB, AA-PLWN4AB RATING: 7.4VDC 6000mAH 44.4Wh Lithium-Polymer Battery Pack in another battery announcement location the only difference is in: Lithium-ion Question? Is there a problem? The only scheme I've got is: samsung-530u3c-lotus-13-ba41-01091a-ba41-01092a . Where to start finding the fault of not charging the battery? |
Гектор [ 21 фев 2018, 02:50 ] | ||||
Заголовок сообщения: | Re: ultrabook samsung (lotus 13 ba41-02040A) NO CHARGER BATTE | |||
can start with the charger
eletmoraes [ 24 фев 2018, 00:48 ] | |
I installed Windows on another hd and, after completing the installation, the battery charge marker was fully charged. When I removed the power cord from the power supply of the Ultrabook, the battery was uncharged and there was no charge signal |
Гектор [ 24 фев 2018, 03:01 ] | |
Do you have a laptop on the charger, and the battery does not break so? |
eletmoraes [ 08 мар 2018, 17:49 ] | |
Now I am verifying that when I remove the motherboard from the enclosure, it even connects but when I put it in place and screw it into the case the motherboard does not turn on. |
