Заголовок сообщения: ASUS MAXIMUS VIII EXTREME ASP1405I DUMP
Добавлено: 23 мар 2024, 15:00
Зарегистрирован: 22 мар 2024, 14:33 Наличности на руках: 10.00 Сообщения: 2 Откуда: Turkey
Hello, we have an ASUS MAXIMUS VIII EXTREME model motherboard. The motherboard uses 2 ASP1405I, also known as IR35201 pwm controllers, for CPU power. I could not get the dump file because the PWM integrated circuit that controls the VCCGT phases was in a short circuit condition. I wonder if anyone has this motherboard or keeps the dumps?
Thank you..
remworker
Заголовок сообщения: Re: ASUS MAXIMUS VIII EXTREME ASP1405I DUMP
Добавлено: 30 мар 2024, 05:33
Зарегистрирован: 20 мар 2016, 09:20 Наличности на руках: 31.03 Сообщения: 17 Откуда: Россия
I took the dump a long time ago....
MAXIMUS_EXTREME.zip
sistemon
Добавлено: 30 мар 2024, 10:58
Thank you very much. You've brought the motherboard back to life.
