Текущее время: 25 апр 2024, 19:20
 Заголовок сообщения: NAS QNAP TS-453B QY47
СообщениеДобавлено: 01 июн 2020, 18:10
Hi, have a NAS QNAP model TS-453B with QY47 motherboard.
When power is applied to dc-in conector, (12v) it starts to drain 80 mA. from PSU.
Power led blinks at low rate and does nothing.
There are some activity in ec-bios but no activity at all at main-bios.
All main voltages are present but no cpu vcore.
This board mounts a IT8528E kbc, but connections are different to other boards with the same kbc.
(only a few pines like spi bus, ec-RST#, and 3v. lines are connected like in Quanta U93)
Without schematic is a nightmare to find out signals like RSMRST# or HWPG.
Can someone help me with this board?
 Заголовок сообщения: Re: NAS QNAP TS-453B QY47
СообщениеДобавлено: 01 июн 2020, 18:26
you can check is there an EN signal for CPU PWM IC.
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 02 июн 2020, 19:04
This board have 2 identical chips for power the cpu.
One of them works perfectly well and outputs 1.05 volts.
The other one is for cpu-vcore and has no output.
this chips (3H=3H) seems to be identical to RT3601EAGQW_WQFN28_4X4.
The enable pin for this chip is pin 2, and it is low level all the time.
The Compal LA-D641P uses this chip for +VCC_VCGI.
СообщениеДобавлено: 15 июн 2020, 15:18
I have replaced ITE chip (IT8528E) but not solved the problem.
Seems that SUSP# voltage are not generated by kbc chip or an intermediate circuit.
There are some chips that receives +3VALW or +5VALW in some of its pines but there are no output nor control voltage.
Can someone tell what kind of chip are those shown in the photo attached?
(u2, u3 and u19)
Вложение:
СообщениеДобавлено: 15 июн 2020, 22:24
your photo has a bad quality.
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 16 июн 2020, 13:46
You are right, it is very difficult to see the name on top of chip, even with microscope.
I have taken many photos, but it was with my phone camera. ( my good camera is broken)
Take a look at this better photo attached:
(Is the same kind of chip from other circuit in the same board)
Вложение:
СообщениеДобавлено: 04 авг 2020, 00:50
Some good news.
After change the cpu without positive results, I have dedicated all my efforts to find out an equivalent of the ZSA0.
At Aliexpess website, have found that tps22965 is a direct equivalent.
The datasheet of tps22965 described it as "Integrated Single Channel Load Switch"
You can see in the datasheet that pin 3 controls the transfer input voltaje to the output.
I have found a "sot-23-3" mosfet near those tps22965, (3.3 and 5v switches) that has 3v in its drain pin a few miliseconds after power on.
Conecting the control pins to this tini mosfet, the motherboard is able to start an boot from a linux pendrive.
I know that there is a lot of work to do, but things are progresing well.
Вложение:
В этой теме нет новых непрочитанных сообщений. Nas QNAP TS-112 помогите опознать шим
sanchelo81
2053
15 дек 2020, 12:13
AVN Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. NAS QNAP TS-251 подбор SoC на замену.
Стрелок
03 апр 2024, 12:26
Rostyk.07 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Ищу схему сетевого накопителя QNAP TS-809 Pro
AL._.EX
03 май 2017, 14:24
AL._.EX Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. QNAP TS-231P
VVS987
21 май 2020, 01:03
VVS987 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Qnap TS 872XT Q012
buch.alexej
13
1078
23 сен 2023, 18:35
buch.alexej Перейти к последнему сообщению
