Текущее время: 28 мар 2024, 19:49
 Заголовок сообщения: Fujitsu Primergy TX100 D3009 A-11 PCIe problem
СообщениеДобавлено: 28 сен 2017, 17:30
Hi
I have problem with motherboard Fujitsu D3009-A11 which is fitted in some kind of server Fujitsu PRIMERGY TX100. I Have problem with PCIe slots.
Motherboard has 4 PCIe slots:
slot 1 PCIe x1
slot 2 PCIe x4
slot 3 PCIe x8
slot 4 PCIe x8
Motherboard I would like to use for mining, but when I plug 4 graphic cards GTX1060, it is recognisioned only in slot 3 and 4.
When I plug old graphic card AMD Radeon HD6450 in to the slot 1 or 2 is working without any problems, even if two GTX are connected to slot 3 and 4. In device manager visible 3 graphic cards. :du_ma_et:
I would like to connect 4 GTX1060 graphic cards to this motherboards, is it possible that is some kind of lock in BIOS on PCIe slots?
I have two motherboards and both has the same issue...
Anyone can help me to solve that PCIe issue? Is not much information about this motherboard on google so I decided to ask for help.
Thanks
Jacek
 Заголовок сообщения: Re: Fujitsu Primergy TX100 D3009 A-11 PCIe problem
СообщениеДобавлено: 31 окт 2017, 17:21
Does anyone have any ideas?
Is it possible that is a north bridge issue?
СообщениеДобавлено: 25 дек 2017, 16:24
How much PCI-lines on your processor?
СообщениеДобавлено: 25 дек 2017, 21:45
Your card need PCIe 16x slot, but your motherboard only has one such port.
Цитата:
PCI slot
Type
Function
PCIe x1 (notched)
PCIe x1 slot Gen 2 (mechanically x4)
PCIe x4 (notched)
PCIe x4 slot Gen 2
PCIe x8
PCIe x8 slot Gen 2/3
PCIe x8
PCIe x8 slot Gen 2/3 (mechanically x16)
GTX1060 user manual
http://www.nvidia.com/content/geforce-g ... _Guide.pdf
Fujitsu D3009-A11 user manual
http://manuals.ts.fujitsu.com/file/1032 ... -tm-en.pdf
В этой теме нет новых непрочитанных сообщений. Fujitsu D3009-a11 gs 3 ищу дамп биоса
al51al51
18 авг 2020, 11:13
al51al51 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. fujitsu siemens primergy tx300 s4 Не заходит в биос
alexivan1195
13 дек 2017, 17:03
alexivan1195 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Fujitsu PRIMERGY RX300
в форуме Программное обеспечение | Software
immigacy
22 июн 2021, 15:34
immigacy Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Pavilion TX100 (DA0TT8MB08E) start up and shutting down instantly
bomi123
2849
12 апр 2016, 00:48
scorpic Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. 1050Ti KFA2 LP works/работает in PCIE x1 but not/но нет in PCIE X16 (X8)
cxav
24 фев 2023, 20:44
karlan Перейти к последнему сообщению
Сейчас этот форум просматривают: partner и гости: 11
