I am working this motherboard that presents almost the same issue like this one:
viewtopic.php?f=53&t=38822In stand-by mode are present 3.3v and 5v.
When power button is pressed, the current consumption rises from 23 mA. to 45 mA. and only the 1.5v pwm for ddr3 works. Other pwm for cpu or gpu not work at all.
There is no pulses in bios chip, and the post card shows 00, even in stand-by
I am trying to measure some voltages from ite8519, but seems not to be pin compatibility with other kbc from ITE. (like it8512 or similar)
Is there any schematic that can I use like a guidance?
Thanks.
