Текущее время: 19 апр 2024, 17:40
Внимание! Скачивание вложения в этом разделе стоит 10 Баллов.
Attention! Cost for attachment in this forum is 10 Points.
 Заголовок сообщения: LTN173KT028 Samsung 17" lcd screen
СообщениеДобавлено: 18 май 2019, 20:02
Hi, need data dump for LTN173KT028 Samsung 17" lcd screen.
The original one is corrupted and not show image, also back-light is off in Samsung laptop.
I have reprogrammed a dump from Vlab, but seems is not 100% compatible with original. (shows some pixelation)
This is the dump tested: viewtopic.php?f=91&t=10709&p=658859&hilit=%2Altn173%2A#p658859
Thanks in advance.
note: included the faulty original.
LTN173KT028.7z
 Заголовок сообщения: Re: LTN173KT028 Samsung 17" lcd screen
СообщениеДобавлено: 19 май 2019, 19:00
andromedax
Can someone share the datasheet for LTN173KT028?
I have compared the LTN173KT028 with the one downloaded, (LTN173KT01-A01) and are practically the same.
The major difference are in bytes from byte 018h to 020h that holds values for RGB.
I don't know with values are the wrong one, but that makes the lcd work with pixelation or not to work at all.
Thanks for your help or comments.
Edit for adding pictures.
СообщениеДобавлено: 22 май 2019, 20:26
The problem is solved.
Someone lend me a 17" LG screen, and data for this LG are compatible with those in the Samsung screen. :ya_hoo_oo: :ya_hoo_oo:
If someone need this dump, can download from: viewtopic.php?f=100&t=5575&p=672529&hilit=%2ALg+LP173WD1+TLC%2A#p672529
В этой теме нет новых непрочитанных сообщений. Dell Insprion 7567 (bbv00/10 la-d993p rev 1.0) No screen, black screen.
в форуме Dell
anarasgarli
22 фев 2018, 14:23
anarasgarli Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Whether there is a possibility to repair the defect of the LCD screen
в форуме LG
eletmoraes
27 май 2016, 01:28
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Pavillion DV7 (DAUT1AMB6D0 REV:D) No hdmi, vga or lcd screen output
andromedax
25 май 2017, 03:22
desska Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. tv LCD AOC LE32D1440/20 after I turn on the TV, the AOC logo appears on the screen
в форуме LCD
eletmoraes
25 окт 2018, 00:00
В этой теме нет новых непрочитанных сообщений. What procedures, equipment, and materials do you need to remove and glue the flat of the LCD TV screen?
в форуме LCD
eletmoraes
20 май 2019, 08:05
mia Перейти к последнему сообщению
Сейчас этот форум просматривают: speedyhka и гости: 4
