Текущее время: 24 апр 2024, 23:32
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 20 июл 2020, 17:57 |
Зарегистрирован: 27 фев 2020, 13:07 Наличности на руках: 323.76
Сообщения: 295 Откуда: romania
RsM писал(а): primary coil consist of 2 coils It has only one for me read the post above. I got 350uH after I put tape on outside of the core. The primary coil is 99% as it was I just removed a small wire which was making short. It can drop from 750 to 350 because of small gaps in the core after glue?
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 21 июл 2020, 07:16 |
RsM писал(а): But 350uH is not enough anyway But there is no gap in core after i tape it all parts are in contact as it was before. Hmmm I should not open it at all I think that if I applied DC on primary coil the short may disappeared but now it is too late.
mia
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 21 июл 2020, 10:23 |
ilie321 писал(а): I think that if I applied DC on primary coil the short may disappeared It's impossible.
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 21 июл 2020, 11:24 |
It was a very small wire 0.1mm in short. But this does not matter. Why only 350uh if is not good? Because I break the core and now the small gaps can reduce so much the inductance?? Grrr. I can't find oval core to replace it :(. If anyone with same psu could measure inductance :) . This it will work? https://www.tme.eu/ro/details/etd39-3c9 ... erroxcube/ ?
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 22 июл 2020, 10:38 |
RsM писал(а): 1500uH primary coil Wow alot. So 350uH no way to work? For me external coil is 50uH. A schematic grr to see the real value of this coil will be good :(. So breaking the core made it so low even if is in good position after glue. Edit: seams my lmeter measure is 20% less than real so external coil has aprox 60uH so it is like 62uH you measured. And for primary coil I have aprox 420uH stil low :(.
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 23 июл 2020, 14:36 |
RsM писал(а): It is important to set up right nonmagnetic gap. From my pictures with core there seams to be a gap no? But if you see first picture it has a small area of contact. So it is with gap after all or not?
RsM
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 05 авг 2020, 14:06 |
Модератор |
Сообщения: 8256 Откуда: Сыктывкар
12V lamp from auto or galogen from electric store, hand-made coil from NiCr - here or here
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 06 авг 2020, 23:01 |
I just received a info from Thermaltake forum that value should be 450uH hmmm i had 420 and core had some gap so maybe it is true. if core already has gap small spaces due to glue don't influence much the inductance Вложение: image.png.aae5ae2a73e4a3f450381834b5b8c6d1.png
ilie321
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 07 авг 2020, 10:29 |
RsM писал(а): It is not a load. minimum is 150W-400W Any things to check when put load on it? Temperature signals etc?
mia
Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help Добавлено: 07 авг 2020, 17:51 |
ilie321 писал(а): I tested 30secs with 55w 12v bulb and seams ok. Do I need to test more power? Or more time?
Need to test more power and more time with eg resistive load made by parallel connecting high watt low resistance resistors depend of load for each voltage channel corresponded with specifications. All main channels must be loaded at the same time.
