Заголовок сообщения: Toughpower Grand RGB 1200W Platinum SHORT-CIRCUIT
Добавлено: 24 окт 2023, 20:26
Зарегистрирован: 30 окт 2021, 17:20 Наличности на руках: 2.11 Сообщения: 97 Откуда: England
I found a damaged circuit, which broke the following components: UBIQ QM3054D B06N03 APW7159C However, now it says that it is not in a short circuit, but as soon as it turns on, it immediately turns off as protection. Can anyone help me check the circuit? PS_ON only tests with 2.64V.
Radio2865
Заголовок сообщения: Re: Toughpower Grand RGB 1200W Platinum SHORT-CIRCUIT
Добавлено: 25 окт 2023, 09:20
Зарегистрирован: 27 ноя 2016, 17:45 Наличности на руках: 97.45 Сообщения: 1002 Откуда: Ташкент
first you need to properly design the topic according to the topic design rules, you need to describe the composition of the power supply
Сейчас этот форум просматривают: crazy_mad и гости: 26
