Текущее время: 23 май 2024, 12:48
iobuggy
Заголовок сообщения: Asus expedition GTX 1070 no power to MEM,GPU,PLL. Добавлено: 18 янв 2019, 01:06 |
Сообщения: 16 Откуда: belgium
Hi guys, I have a GTX 1070 with no power to GPU,MEM,PLL<PEX_vdd>. Where to dig guys?
Apex
Заголовок сообщения: Re: Asus expedition GTX 1070 no power to MEM,GPU,PLL. Добавлено: 20 янв 2019, 16:02 |
Зарегистрирован: 26 дек 2017, 15:04 Наличности на руках: 35.44
Сообщения: 44 Откуда: Helsinki
I can help you in English, but I'm not an expert on diagnosing GPU faults correctly.
For the gpu part, I would check the mosfets under the black heatsink. For vram voltage, check the ones on the right side above the inductor. You can find info on how to test mosfets/transistors online. If they are ok, then they're not opening, in which case you should check the PWM controller with the mosfet drivers in charge. Once you locate the PWM, find its datasheet and check the pinout. Make sure it's getting VCC and EN signals. That's just the basic stuff.
Notice, there might be drmos type of transistors which consists of both mosfet and driver in one package (probably not in your case). Those are trickier to test. You have to look at the datasheets either way.
