Текущее время: 23 май 2024, 16:42
 Заголовок сообщения: Sapphire R9 390 nitro no display
СообщениеДобавлено: 06 мар 2020, 20:08
Hello i have an r9 390 that has all voltages ok. It is detected in windows if i use second card. I write last bios with atiflash.
Maybe ram voltage not ok? 1.500V only if fan connected(my first amd gpu open). should be 1.6V?
Any ideea?
Thank you.
 Заголовок сообщения: Re: Sapphire R9 390 nitro no display
СообщениеДобавлено: 09 мар 2020, 09:16
Anyone? Thanks
СообщениеДобавлено: 09 мар 2020, 12:14
Check picture for all videoout - DP, HDMI, DVI. Check resistance on all signal lines. Check voltage 5v for DVI, HDMI and 3,3v for DP.
СообщениеДобавлено: 10 мар 2020, 10:03
i checked all signal lines and are ok
Check voltage 5v for DVI, HDMI= ok
but it stop in B2 if the card is alone in the system ;
for memory 1.500V is ok?
it has a strange pwm also for memory:
СообщениеДобавлено: 10 мар 2020, 11:31
ilie321 писал(а):
memory 1.500V is ok
it is ok.
if card stop on b2 - it is memory error (for AMD videocards). test and change fail memory bank.
СообщениеДобавлено: 10 мар 2020, 11:40
any way to test memory for amd? is my first amd :)
СообщениеДобавлено: 10 мар 2020, 11:58
read this viewtopic.php?f=48&t=91866&p=683466&hilit=%2A%D1%81%D0%BA%D1%80%D0%B8%D0%BF%D1%82%2A#p683466
СообщениеДобавлено: 11 мар 2020, 09:53
Hello i tried that script.
Lspci give b0000000 and c0000000 which is ok to test? For b000000 i get 1.000... and i have 16 modules of ram so 1 is damaged?
If i test c0000000 i get 4. 000... so 16/4 4 modules with errors.
If i add it as second gpu driver says ok but no image if i put monitor.
СообщениеДобавлено: 13 мар 2020, 21:57
How do i find the reset resistors for memory with no schematic?
СообщениеДобавлено: 14 мар 2020, 21:18
I found 2x2 memory not ok with the script. I used a 4.7ohm resistor to short to ground the resistor where was 1V measured. Like 30ma were taken 1-2 seconds. Now i need to find same memory types the replace all 4. I tried reflow on them with no success. I used as command "python3. /direct-mem-test.py b0000000 1" ; 1mb was enough and i had 16 ic memory chips so 65535kb on each. If chip was disabled the number of errors increased by 65xxx for good memory and almost at all for bad ones.
В этой теме нет новых непрочитанных сообщений. Горизонтальные полосы на экране (Sapphire Nitro R9 390 8G GDDR5)
saveandrey
3008
21 мар 2018, 18:32
saveandrey Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. SAPPHIRE NITRO R9 390 8G горят DrMos
Dektor
21 фев 2022, 02:34
vovikmm Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sapphire Nitro R9 390 8G Нет питания GPU и памяти
Homeniuk_Oleh
16
5344
26 авг 2022, 12:48
Opacky Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sapphire R9 390 Nitro 8 GB не отображает изображение
mikazuki
14
3784
04 апр 2020, 09:11
mikazuki Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sapphire R9 390 Nitro 8Gb слишком низкое сопротивление изображения на AUX и памяти
netcrusher
03 мар 2022, 10:19
