Текущее время: 01 июн 2024, 19:44
 Заголовок сообщения: GTX 1050 PNY (ZOMBIE)
СообщениеДобавлено: 24 май 2020, 00:51
hello masters, let me tell you my studies on this card, I had this PNY 1050ti card working normally, I had already removed its gpu to use on another pcb (gigabyte) the transfer was made and the gigabyte went to the home of a happy friend. ifz this because his 1050ti had failed and I knew that the pny of the pny was ok, as the gigabyte has 1 more phase in the vrm I preferred to transfer it to his pcb. but going back to the history of PBY 1050TI ... the board here was apparently all functional, all voltages ok, just missing the gpu, and then a GP107-300 gpu from a 1050 from msi appears, which went short and damaged 1 trail from the gate of one of the vrm phases, and then the idea of ​​putting the gou on that pcb, the installation of the gpu and bingo, crossed my mind! no video hahahahaah, but the card is recognized by the pci express in the windows device manager, don't be content with that i removed the bios chip from MSI and put it on the PNY pcb, same result without video ... and as I am a stubborn person, deciding to replace the memories too, the ones that were before it was hynix (4gb), substitutes for, the pcb module MSI elpida, and guess what? no video, my last card up my sleeve will be to re-record the bios (currently from msi) with a 1050 PNY bios that support elpida memory modules. will it work? I didn’t modify anything on the pcb besides suppressing the eproms, is it necessary to change any resistor around it for it to have an effect?
thanks to everyone who read this far.
Posted after 27 minutes 17 seconds:
continuing the saga, I'm trying to re-record the card's bios, however nvflash does not recognize it in the pci express although windows recognizes it, does anyone know how to proceed?
В этой теме нет новых непрочитанных сообщений. gigabyte gtx 1050 низкое напряжение на nvvdd - gigabyte gtx 1050 low voltage on nvvdd
TheMArcos
16 мар 2021, 16:28
TheMArcos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Переделка gtx 1050 в gtx 1050 ti
Normalgleb
06 фев 2023, 19:19
В этой теме нет новых непрочитанных сообщений. Problem graphic card gtx10606PB (GeForce GTX 1060 6GB) PNY
bokin021
2625
18 дек 2018, 21:14
bokin021 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. PNY GTX 1060 6GB без изоброжения помогите разобраться в отчёт мaтса
giorgiisme
11 май 2020, 01:16
giorgiisme Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. PNY GeForce GTX 1080 Ti 11GB Низкий FPS
andyder
22 ноя 2022, 14:35
ll_r1d0_ll Перейти к последнему сообщению
Сейчас этот форум просматривают: sova741 и гости: 17
