Hello, the board reached me, with all the tensions, but no video, after the gpu rebaling the video came back, all the exits are ok, but the fan doesn’t turn, in the msi afterburn and gpu-z they show as if there was rotation , but there is not, tested the fan with the bench source and it works normally. so far this is a new problem for me, i have no idea which circuit controls the voltage that arrives at the fan connector, someone could help me with this, it’s only getting 0.8v on pin 3 of the connector (from left to right, it would be where is the red wire)
