Текущее время: 23 май 2024, 14:27
 Заголовок сообщения: gigabyte gtx 770 windforce- artifacts
СообщениеДобавлено: 06 апр 2020, 21:33
hello, I have this card showing artifacts right after the video drive was recognized, I ran the mats as friends taught in another topic, but I couldn't decipher the reading of the report (I didn't find an explanation in my language, and I don't have the ability in English enough to understand videos without subtitles.)
could someone give me a hint of these 2 errors presented in the mats, which memory modules are they about?
mats version 367.38. Testing GK104 with 20 MB of memory starting with 0 MB.
Errors found. Use -matsinfo for details.
This message will only appear once.
SUBPART RANK0 RD ERR RANK0 WR ERR UNKNOWN ERR
FBIOA[ 31: 0] 0 16 0
FBIOA[ 63: 32] 0 0 0
FBIOB[ 31: 0] 0 0 0
FBIOB[ 63: 32] 0 17 0
FBIOC[ 31: 0] 0 0 0
FBIOC[ 63: 32] 0 0 0
FBIOD[ 31: 0] 0 0 0
FBIOD[ 63: 32] 0 0 0
Rank 0 Failing bits:
A000 A001 A002 A003 A004 A005 A006 A007 A008 A009 A010 A011 A012 A013 A014 A015
B032 B033 B034 B035 B036 B037 B038 B039 B040 B041 B042 B043 B044 B045 B046 B047
Read Error Count: 0
Write Error Count: 33
Unknown Error Count: 0
 Заголовок сообщения: Re: gigabyte gtx 770 windforce- artifacts
СообщениеДобавлено: 06 апр 2020, 23:01
Take a photo from both sides of the video card WITHOUT COOLING :ne_vi_del:
Вооружён и не опасен :ps_ih: 1) Тепловизор Seek Thermal UW-AAA для Android ; 2) Микроскоп с HDMI выходом Eakins ; 3) Блок питания LW 3010D DC 30V 10A ( к райзеру + провода 8+8pin для питания видеокарты ); 4) Станция Gordak 863 3 в 1 ; 5) Мультиметр UT61B ; 6) Программатор MiniPro TL866CS 7) Осциллограф Hantek DSO5102P .
СообщениеДобавлено: 07 апр 2020, 02:18
hello,
there are the images.(my cam is terrible)
СообщениеДобавлено: 07 апр 2020, 08:11
reball this and run mats again
СообщениеДобавлено: 05 июл 2020, 19:49
Please tell me the value of the resistor R121Изображение
СообщениеДобавлено: 06 июл 2020, 20:38
Most likely it is 0R resistor. My multimeter shows between 2.2 and 2.8 but i cant calibrate it and its always shows that values when i have full short so 99% 0R resistor should be oki.
В этой теме нет новых непрочитанных сообщений. GIGABYTE GTX 770 WINDFORCE
Барзанукаев Ислам
17 янв 2019, 13:33
kolyandex Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GTX 770 2gb gigabyte windforce u1
Мастер из Вашингтона
14
1370
16 окт 2020, 19:49
Мастер из Вашингтона Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. не определяется Gigabyte GeForce GTX 1060 WINDFORCE OC
nikolas56rus
15
5055
23 апр 2019, 23:11
nikolas56rus Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Нужна помощь по GIGABYTE GTX 1070 WINDFORCE OC 8G
JayS
860
20 окт 2020, 12:10
JayS Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Gigabyte GTX 1060 WindForce 3Gb - нет изображения
miant
3575
22 май 2021, 18:56
djigor3 Перейти к последнему сообщению
Сейчас этот форум просматривают: EgorychevDenis, Sivixman1337 и гости: 16
