Текущее время: 04 июн 2024, 03:12
TheMArcos
Заголовок сообщения: Re: Asrock RX580 - strange behavior Добавлено: 12 авг 2020, 16:29 |
Зарегистрирован: 18 мар 2020, 04:02 Наличности на руках: 21.68
Сообщения: 184 Откуда: Brasil
I was able to replace the Gs9230 (via alixpress, which takes time), and recover the components that were torn off at the back of the pcb, the 0.9v came back, but another problem appeared, when the pci supply cable is connected to the card, the 0.9 disappear, add the 5v of the vcc and 2.7 in the enable. I also noticed that the gs7103 doesn't have the vcc voltage (5v) I tried to follow where this power comes from with continuity tests of the multimeter, but the most I managed to get was on the PWM vcc, has anyone ever been through a situation like this? any suggestion?
TheMArcos
Заголовок сообщения: Re: Asrock RX580 - strange behavior Добавлено: 25 сен 2020, 07:47 |
hi guys, Replaces the up9505 and the memory voltages went up, PLL, however I don't have Vgpu, I noticed that I have 0V on one of the pins of the logic port and, this voltage should come from the u100 (74AUP1G57PM) that is close to bios. however I have 0v on pin 6, and I didn't understand what that pin does and where it comes from. his resistance to the gnd is infinite. follows an image for clarification, I would like a tip, about what would be this sign that is missing and what to do to enable it. already replaces Ci but without result. pin 1:3.3v pin 2:0v pin 3:3.3v pin 4: 0v pin 5: 3.3v pin 6: 0v poems about long time friendship
TheMArcos
Заголовок сообщения: Re: Asrock RX580 - strange behavior Добавлено: 29 сен 2020, 07:29 |
aleksros писал(а): signal PERST from motherboard. slot PCI-E16 contact A11. check that signal on MB without videocard. try change U100 hello, I changed u100, 3.3v in powerok in pwm appeared, but still without gpu voltage, I noticed that I have 3.3v in VHOT, is this correct or is it a false alarm?
